Slate Virtual Buss Compressors - Page 2
Old 11-09-2014, 12:09 PM   #21
surgeongeneral
Eternal Echoer
surgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MCsurgeongeneral is a savage MC
surgeongeneral's Avatar
MC Status: 12446483
Re: Slate Virtual Buss Compressors
Originally Posted by relic View Post
Haha...well..it is possible Mr.Slate's software may have done fucked up my studio workstation!
What happened?
surgeongeneral is offline   Thanks Reply With Quote
Old 11-09-2014, 04:30 PM   #22
RFJ
IDMf ArtistModerator
RFJ's Avatar
I live in California.
MC Status: 199649168
Did you get it sorted out?
Old 11-09-2014, 04:43 PM   #23
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8567130
I have no idea.
There are 4 different versions of every plug in 32 and 64 bit in VST2 and VST3. Some of them load, but with no GUI though if I click and drag on certain areas on the window of the VST wrapper I can see that parameters are changing (FL studio has a neat little feature that display parameter changes outside the VST's window).
Sometimes I get a "VST disconnected error" with ilbridge.
When I first installed VBC and opened an old project it no longer recognized Slate VTM and couldn't load it. So I fucked around getting that back up and running, ended up reinstalling the iLok manager too. Finally got all my Slate plug ins except VBC working.
Then I opened that project again and it was unable to find Maschine along with several other plug ins. Ended up reinstalling FL Studio, newest 11.x. VBC still doesnt work, but everything else seemed to be fixed for the moment.
Of course Slate doesn't list an specific support for FL Studio on their website. I will get a ticket going with there support tonight, I can't remember enough specifics to do it from my office.
I'm also just going to have to take a look at my system over all and check for errors. I'm somewhat worried it might be a bigger issue. I just installed Komplete 9 as well and wonder if maybe my HD is going bad since a lot of funky shit is happening...
I may actually try installing the legacy version first.
Old 11-09-2014, 04:48 PM   #24
strkssinthes
Soundscaper
strkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MCstrkssinthes is a savage MC
strkssinthes's Avatar
MC Status: 38420
Ahh Virtual Tape Machines has been on my list for awhile but I just can't get past the ilok component. It's more of a stupid ego thing not having one plugged into my USB port.
strkssinthes is offline   Thanks Reply With Quote
Old 11-09-2014, 05:11 PM   #25
surgeongeneral
Eternal Echoer
MC Status: 12446483
That sucks Relic!
FWIW- I've had a pretty painless experience in Ableton. It could be an iLok issue as well. I hope you figure it out because these compressors are awesome.
Old 11-09-2014, 05:28 PM   #26
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8567130
Originally Posted by surgeongeneral View Post
That sucks Relic!
I'm also going to install the latest version of Reaper when I get a chance to work on the problem again. Just to check if it is a an FL Studio specific issue. I've been contemplating making the switch from FL Studio to Reaper anyway...maybe this is a sign...
I've never had an iLok problem with Slate in the past...or Waves for that matter... and I can't imagine what that problem would be...everything in the manager says things are activated and OK. But who knows.
Old 11-09-2014, 05:35 PM   #27
surgeongeneral
Eternal Echoer
MC Status: 12446483
Hang in there, man! It will be worth it!
Thanks to surgeongeneral
relic (11-09-2014)
Old 11-09-2014, 05:36 PM   #28
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8567130
IF my whole system isn't melting down, I'm sure it is only a minor issue ;p
Old 11-09-2014, 07:11 PM   #29
MFXxx
MFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MCMFXxx is a savage MC
MFXxx's Avatar
My own little world
MC Status: 1843927
In regards to slate plugins I am sure there's a GUI issue with latest drivers if you're on Nvidia, [Only registered and activated users can see links. Click here to register]
Change Log For VBC
Version 1.2.4.1
Bug Fixes:
Workaround - Rollback to NVIDIA Drivers 335.23 available here:
However Im now on 340.52 driver, Win8.1prox64, cubse 7.5.6x64 and running all the latest beta versions of VCC, VTM, FGx and VBC. No issues apart from FGx crashing Cubase on relaunching a project if active as an insert in the Buss (just switch it off befoew saving and closing).
Latest verson of VTM have does not work in FL 11 (latest version of both), jsut tested as I noted you're a fruity user.
My Tinkerings
https://hearthis.at/mystafx/
https://soundcloud.com/mystafx
Not forgetting the awesome Beat Battle Subs
https://hearthis.at/mfxxx/
MFXxx is offline   Thanks Reply With Quote
Thanks to MFXxx
relic (11-09-2014)
Old 11-09-2014, 07:33 PM   #30
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8567130
Many thanks! I am just using the onboard graphics of my mother board (no idea what that is, but I will check).
Funny about FL 11.x and VTM...I just updated to the newest version of FL 11.x and VTM (also latest version) loaded just fine, but I didn't try running audio through it or anything.
Old 11-09-2014, 07:39 PM   #31
MFXxx
MFXxx's Avatar
My own little world
MC Status: 1843927
Maybe the version are you runing FLx32 (im on x64), don't have much 32bit audio programs installed (apart from Vanguard, Bootsie and a few other minor freewares).
But I have never taken time out to learn FL (Reaper or Sonar), purchased a while back. If I have time to learn it, I'd rather be tinkering in Cubase
My Tinkerings
Old 12-09-2014, 11:15 PM   #32
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8567130
Fuck me...VTM doesn't work in in FL Studio 11.x...
Old 12-09-2014, 11:24 PM   #33
surgeongeneral
Eternal Echoer
MC Status: 12446483
God damn. I wish I could help you. I'm a Mac/Ableton guy. Does the VBC work at least?
Old 12-09-2014, 11:48 PM   #34
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8567130
Lol. No. It doesn't :p I'm going to get it sorted with Slate. No worries. Thanks though : )
[Experimental Beats] TokiMonsta - Clean Slate (Quinton Aiken Remix) Delonchaw Listening Booth 1 11-07-2013 06:53 PM
Master Buss Compression/Limiting Questions Tkow Sound Design, Mixing, & Studio Techniques 21 21-05-2012 12:20 AM
Reverb send and drum buss confusion wet_nitemares Sound Design, Mixing, & Studio Techniques 1 03-05-2012 04:29 PM
A completely blank slate here. GenretScratch Introduce Yourself 2 01-03-2012 08:29 AM
Buss compression, when to use it and what settings!? robodelfy The Studio 17 09-11-2011 09:55 PM
