effects we dont know about - Page 3
Old 09-02-2017, 04:47 PM   #41
Metaside
Metaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond repute
Metaside's Avatar
MC Status: 8010
Re: effects we dont know about
Thanks, glad you like my track!
Btw., the Unfiltered Audio stuff is on sale right now at Plugin Alliance in case someone wants to spend some money ^^
Metaside is offline   Thanks Reply With Quote
Old 12-04-2017, 08:37 PM   #42
Metaside
Metaside's Avatar
MC Status: 8010
Two of the three spectral effects that have been announced have been released already - both are a little bit on the expensive side, though:
Eventide Structural Effects Fission - splits transient and tonal parts of a signal and allows for separate pitch-shifting, EQing and other effects. Very handy as a mixing tool for nearly everything from subtle manipulations to complete drum-reshaping and other stuff. Especially nice for drums, vocals and effect sounds in a mixing context imho.
Zynaptiq Wormhole - a tool for pitch and frequency shifting and spectral-warping that has the nice advantage of integrating a morph function (a simplified version of Zynpatiq Morph) between wet and dry version instead of a simple crossover fader. I heard some good and some bad things about the quality of the new pitch- and frequency-shifting algorithm, I personally think it does the job well but it may not be the best tool if you are looking for a simple pitchshifter. Instead, it is really good for harder transformation of voices and other signals and then morphing between wet and dry versions. Also, it is great for crazy modulated spectral manipulations, but Zynpatiq does not provide any modulation options inside of the plugin so you have to use your DAW for that. If you are shopping for spectral tools but want internal modulation I would recommend waiting for Unfiltered Audio SpecOps, since their products always have a great modulation system.
Thanks to Metaside
Parricide (14-04-2017)
Old 07-08-2017, 09:40 PM   #43
Xinus
Analog Lurker
Xinus has a spectacular aura aboutXinus has a spectacular aura aboutXinus has a spectacular aura about
Copenhagen
MC Status: 210
Hey saw you were talking about SpecOps. I'm currently beta testing it and it is awesome! I made a demo video and track with it which you can find here:
Xinus is offline   Thanks Reply With Quote
Old 14-08-2017, 02:21 PM   #44
localspace
Analog Lurker
localspace is a glorious beacon of lightlocalspace is a glorious beacon of lightlocalspace is a glorious beacon of lightlocalspace is a glorious beacon of lightlocalspace is a glorious beacon of light
MC Status: 460
I'm having a lot of fun with Scapes by twistedtools. It's a granular delay effect so that's nothing new, but it is to me and it packs a whole lot of options that make it really usable and playable.
It has step sequencer, can receive midi notes and there's 6 layers that can be incoming audio, loops, or oscillators which can then be manipulated individually with easy sliders. If you've ever used anything by twistedtools before, it should be familiar right away.
localspace is offline   Thanks Reply With Quote
Old 15-08-2017, 10:12 AM   #45
starphase
starphase has a spectacular aura aboutstarphase has a spectacular aura about
starphase's Avatar
Palo, Leyte
MC Status: 160
Riding the faders also counts, right?
Though if we're talking about preset effects that are sometimes (or often times) stealthily used by producers: gates, specific EQ settings and multiband dynamics are probably up there.
Also Amps. I love distorting sounds with those.
starphase is offline   Thanks Reply With Quote
Old 15-08-2017, 10:31 PM   #46
Bluesh1ft
Sample Destroyer
Bluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond repute
Bluesh1ft's Avatar
In another world, usually
MC Status: 2710
Unfortunately, I think the answer is layering. But maybe someone could make some new effects that kinda layer different effects together. Introducing the Cave VST- reverb and physics modeling. The wideness of a cave and all those little plinka plonks you could hear inside a cave. All those juicy fruit splash epic caveness you hear in modern electronic music in one vst.
Bluesh1ft is offline   Thanks Reply With Quote
Thanks to Bluesh1ft
Vault O))) (16-08-2017)
Old 16-08-2017, 11:30 AM   #47
Vault O)))
Buttcase
Vault O)))'s Avatar
St. Augustine
MC Status: 54310
That's where the DAW comes in. Plus, there are loads of experimental effects units that exist (niche guitar pedals are a great example of this) which essentially just blend multiple things together.
That's why Jesus made the macro knob, I think that's what I'm getting at.
Thanks to Vault O)))
A.M (16-08-2017)
Old 16-08-2017, 01:04 PM   #48
A.M
IDMf SupporterIDMf Artist
A.M's Avatar
MC Status: 198410
I thought it was the other guy who made that..oh, shit..what's his name?
Thanks to A.M
Old 23-08-2017, 10:48 PM   #49
artificialmusic
IDMf's latest spammer
artificialmusic is currently spamming hard
using long effects chains and then recording to audio and repeating works well. modulating the effects in a musical way with each other like you would regular music notes will get you things you wouldn't expect, especially when used in large amounts. just put all your effects on one track and bada bing bada boom. f*** it!
artificialmusic is offline   Thanks Reply With Quote
Old 29-08-2017, 12:21 AM   #50
Ardacris
Ardacris is currently spamming hard
Ardacris's Avatar
Hessen
I don't really know if this effect is known by a lot of people, i discovered it on accident:
Use an auto panner and pan the signal with a high frequency, eventually the frequency will become audible and add to the original. Very wierd effect, useful for Alien-like vocals or something similar.
Cheers
Ardacris is offline   Thanks Reply With Quote
Old 30-08-2017, 06:56 AM   #51
Parricide
Parricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MC
Parricide's Avatar
MC Status: 18027769
Cheers
amplitude modulation
signature loading...
Parricide is offline   Thanks Reply With Quote
Thanks to Parricide
Br/ainfu+ked (08-05-2018)
Old 31-08-2017, 12:54 AM   #52
Ardacris
Ardacris's Avatar
Hessen
Well yeah, that's the basic principle behind it, i know.
But using it by panning something.. nothing i have ever seen/ consciously heard anywhere.
Am I wrong? I think the Crysis guys may have used it for the Suit-Voice^^
Old 02-09-2017, 05:04 AM   #53
Parricide
Parricide's Avatar
MC Status: 18027769
yea, you will get different results depending on your panning method, e.g. balance is just AM, but true panning will mix the L into the R and vice versa.
Old 24-09-2017, 09:24 AM   #54
Metaside
Metaside's Avatar
MC Status: 8010
All the spectral tools I was talking about some months ago are out now: Fission, Wormhole and SpecOps. After testing all I would probably recommend SpecOps for most creative applications because of its flexibility and internal modulation system. Fission is a great mixing tool, especially fur drums, mixed beats and basically everything with transients but I don't use it much for sound design. Wormhole has a great sound but very limited flexibility and no internal modulation. A really nice bonus is the morph function to morph between wet and dry signals, though, awesome for sound design.
Also, there's a new 64bit version of the freeware DtBlkFx for all who want to do some spectral mangling for free :
Some VST effects dont have output vol control... help me out guys D42K732202 The Studio 15 18-11-2016 02:26 PM
Need help, please, I dont know where to start from D42K732202 Industrial / EBM / Power Electronics 18 22-01-2016 07:33 PM
I really dont think I could do this bad if I REALLY tried hard Numerical Music Scene Chat 28 24-08-2012 08:06 PM
Some effects n shit i dont understand wolly9595 Sound Design, Mixing, & Studio Techniques 16 25-08-2011 06:06 PM
